Preset values changing
Scouse_logic
Oct 2019
Scouseland
Be gentle, itÂ’s a first post & IÂ’m learning along the way.
Have checked out this forum and search engines for answers, hopefully someone can point me in the right direction
5562 controller, Rev15.3 & battery is fine.
Had a power outage on a machine, when reset a strange thing happened, timer preset values that had been changed about 6months ago by a specialist reverted back to their original values. The Plc had not lost its program, on changing them back normal operation resumed.
Looking at the program offline, think I may have answered my question, maybe a more experienced person can cast an eye over and let me know if IÂ’m on the right track
Under standard functions there is a first scan, it appears to have all the original preset values in MOV instructions with destinations that match the timers where the values reverted back, as itÂ’s within the first scan, from what IÂ’ve found In the searches this only runs when power is first applied/ after a power outage?
Any guidance will be appreciated
Cheers
Welcome to the PLCTalk forum community !
You have almost certainly correctly identified the issue.
There's a pre-defined operating system tag called "S:FS", a Boolean value which is True only during the "first scan" of each Routine that examines it.
First Scan happens at power cycle, or when the controller transitions from Program to Run mode, like with the download of a new user program.
Processor: 1769-L30ER; Logix 5000: v32.02 I have an AOI that's been used in previous applications without issue, and have added a TON...
2,807
I've tried to add an "s" after the tag for the PT value of an IEC timer but it's rejected, even if the tag type is "time". As the timebase is ms...
2,143
So I have timers in an add-on instruction that work perfect, however I want to change the preset values in all of the instances at once (about 45...
2,904
Hi everyone, probably a simple question, but I can't find it anywhere. The counter and timer commands in TIA Portal (v10.5 SP2) all have presets...
2,208
I am trying to read into KEPware a timer preset value from a Siemens S5 115U PLC. The preset value is saved in a data block but when I look at...
3,998
