print from RTA to epson ticket printer
jameswke
Feb 2015
florida
I am trying to print data from a compactlogix PLC to an Epson ticket printer. I am using a RTA Ethernet to serial (ASCII) converter to connect the PLC to the printer. I am seeing the data on the RTA module but I can't get the printer to print it or do anything. I'm pretty sure I am missing something. any info will be helpful TIA
Jim
I used an RTA module exactly like that to communicate between a CompactLogix L16ER and a DataMax label printer. I set everything up in Logix5000 according to RTA's documentation. I was able to get data to pass to and from my PLC to the gateway using the RTA web page, but just could not get it to go to the printer; or so I thought. After many different serial cables, I finally discovered that my problem was that I was sending the ASCII characters to the printer in the wrong format. Initially I was trying to send it data like "%02n$r$1, %02M0500$r$1, etc." but what I actually needed was "[1]n, [1]M0500, etc."
Long story short, check all of the manuals you can get your hands on, and make sure the ASCII syntax is correct.
Will someone please convert this logic to pdf?
127
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
385
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
144
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
390
I am stuck on a project. I am still somewhat green at PLC programming and had a project given to me to get at BROTHER printer to print via plc...
894
