Printing Alarms From CompactLogix or PV+
demmons
Jan 2009
PA
87
Is there a way to print alarms from either a CompactLogix or a PanelView Plus 1000 via ethernet?
I would only need to print certain alarms at certain times, not all of them.
I guess so. I haven't do anything like that so far but if you are using Factorytalk Vew ME you can select which alarms you want to print on "Alarms Setup" option, then choose "Advanced" and there you you have a check box to give audio, display and/or print the alarm you want.
You can configure your printer through PV+ and assign it an IP to be connected to the network.
Regards,
Is there a way to print out the alarm triggers, trigger values and messages? Ive tried exporting to Excel but FTME locks up everytime I do that.
1,739
200
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
168
I had a student fooling around with settings tonight, and now when I try to print a program ladder, each rung prints on a separate sheet. Too many...
367
Looking to Print over ethernet with a 5069-L320ERMS3 Compact GuardLogix 5380 Safety Controller. Printer model yet to be provided. But a few...
1,622
