Problem about address form_SIEMENS S7-300
EarL.Yu
Jul 2009
Beijing
Hi all,
I declare an array variable as CHAR like this:
VAR_INPUT
ASCII : ARRAY[0..6] OF CHAR;
END_VAR
I create an array variable as CHAR in db1 and I assignment the FC input like this:
CALL FC1
ASCII := "DB1".Data or P#db1.dbx0.0 byte 7
Floating:=
both forms can not be accept.
Please help!!Thanks in advance!!
Hi I have a Mitsubishi FX3GE and I am trying to change the IP address to one that will sit on our network. I am using GX Works 2 version 1.586...
1,907
Hi I use from Delta PLC and I use from EN01 module for communication I assign an IP address to it statically. But I have problem.this IP after a...
2,517
Hi everybody, following the tip of Ken Roach, i'm opening a new thread to my problem. I have a redundant PLC system, each chassis have two...
7,945
Hi, I have a PLC (Micrologix 1500) working with the machine. In my office i have a PanelView Plus 600, I've programmed with the application...
1,741
Greetings, We are having a DeviceNet problem here at the plant. The problem occurred after 5 years of operation and a node on the DeviceNet...
4,720
