Problem creating variable tag array Citect 7.4
poprcac_1989
Dec 2015
Novi Sad
I'm having a problem creating variable tag array in Citect SCADA V7.40. I looked every possible help, user guide... but no matter how i set array I cannot change value of any element of array beside first one.
I configured my variable tag as shown below:
Tag name: TestArray
I/O Device: Internal (it's an OPC Factory Server)
Address: V500[5], %MF4000[5], I2[5], F2[5] (I tried every one of these for REAL or INTEGER type based on user guide/forum posts)
Data type: REAL, INTEGER
I tried every one of these but without success. If i try to set value of variable tag array element, example TestArray[1] and TestArray[4], by typing value in Number field (in Citect Runtime) every element of an array is giving me message #ERR, except first one.
Other than that in Citect Runtime in All variable tags window, I can see TestArray tag as a single tag, not as an array
Note that i'm not using these tags in Cicode but in Graphic Builder / Runtime. I need about about 50 user defined value tags to be sent to SQL DB by SCADA so remote PLC can read those values in order to define state of outputs.
I would highly appreciate any kind of help, any tip. Thanks in advance!
Tag name: TestArray
This may be an OPC driver issue, are you sure it will allow writes to individual elements of an array ?
Have you tried a different driver to check it works ?
Hi, I got a problem when i create new database(under connection folder) for Alarm and Even log viewer.I am using FactoryTalk SE(version7) local...
2,008
Hello, until now I could create a Runtime Application as much times as I wanted. But now, If I do it, the programm tells me that there is no...
2,738
hi all, pls help me to over come this error.i ve open the rsview32 software.when i try to open new project error message was appear.it contains...
2,930
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
