problem to see DBW step 7 siemens
I believe it says:
-Load Data Base Word 280 into accumulator 1
-Load the value of 1 into accumulator 1 which pushes the last contents of accum 1 to accum 2
-If accum 1 and accum 2 are equal Integers
Turn Memory Bit 130.3 on.
In short if DBW280=1 then turn on bit M130.3
place the cursor on the item by clicking the left mouse button on the instruction ==I then press F1 it will give you the help for that STL instruction. The same is true for all those commands.
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
141
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
64
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
91
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
87
23
648
