problem with comunication between proworx 32 and modicon 984
felix1030
Nov 2009
Quito
Hi I have a problem with modicon 984 and the software proworx 32 last version. when I try to conect with the plc in online mode, proworx show this messsage:
toggle the switch to verify memory protection device selection.
I am not sure if it refers to the switch that the modicon has in his module, there is a switch named memory proteccion, or it refers to another thing maybe proworx configuration.
If somebody may help me , I will be so thankfull
There is a dip switch selectable from the outside of the CPU that selects memory protect ON/OFF. Perhaps this is in ON and needs to be selected to OFF.
Brian.
proworx and modicon 984
thanks for your answer.
yes, there is a switch out of the cpu and it is in off mode but I do not know If it is the problem, maybe if I change the switch to onn it works, but what would happend with the Plc's program
hallo guy's, I have problem in comunication between PLC and SCADA. :shoot: I connected the plc with the scada and codesys due the keep server...
1,470
hello everyone, i have problem with communicate between siemens op25 and s5 115u cpu941b. when i upgrading the timer or anything else by using...
1,311
Hi, I have a problem with N2 6SE7138-4FB04-0AB0 we have still the comunication error. SF led on. Someone can help me?
1,766
In micrologix1200 I have only one communication channel so that I do not unable to configure the PLC with Modbus rtu slave driver without losing...
4,266
Dear all , i am using 1756 L 63B cpu and 1756 CNB controll net scaner and comunicate with Pilz PSS 1 DNS (device net sacner ) now i am having...
2,821
