Hello,
I have a little test system, a ML1500 connected to 1761-net-eni with cable HM02 (DF1 protocol) on one side, and on other side net-eni connected to westermo lynx400 (ring optical modem). On optical network I have connected more two SLC 5/05 processors (each on his own lynx400 modem) this two procesors can read and write message in both direction. OK you ask what is the problem? With ML1500 over net-eni I can read and write to both slc 5/05, but with slc i can not read or write to ml1500 over net-eni? The data table is N50:0 and exists in all three plc. I was try with this type message: 485cif, 500cpu, plc5.
All device have own static ip address, and all device is in the same subnet.
"For example settings: IP for net-eni:192.168.2.211(Message Routing: 0 - 192.168.2.221; 1 - 192.168.2.201) his lynx:192.168.2.210, first slc:192.168.2.201 / his lynx:192.168.2.200, second slc:192.168.2.221 / his lynx:192.168.2.220"
Thanks,
Ivan
Thanks,
Ivan
