problem with pl7 pro
max56
Feb 2012
qatar
hii,
i am working with PL7 V4.4 on a micro TSX 57203 plc .
When trying to upload the program from the PLC at final stage the program gives an error "initialization failed,please reinstall the io catalogue".
I have tried reinstalling the software but still nopt possible to get back up of the program.I do not have bkup of the program so cannot use the downlaod option.
Thanks,Max
Is the version of the PLC you are trying to upload present in the hardware list?
it could be your software is too old? I think PL7 is on V4.5 now
Thanks for the reply,
I have tried uploading the program my configuring the Hardware,by selecting the CPU and IO modules from the Hardware configuration Library,
while uploading it shows all the bytes that are uploaded,also it shows that the library is uploaded,then finally it starts initializing and then the error message comes that initialization of the application failed.I have also tried reinsatalling the PL7 pro V4.4 software.,but not able the get the backup,
max
As was suggested i think you are trying to upload from a premium that is a newer sv(version) than what you have on ur software. On the side of the cpu you can see the sv number then compare to what you have in the pl7 pro software
Dear All, I am facing a problem in programming PID in PL7. The output of PID is changing only when Process Value is Changed. which means the KP...
1,215
Hello, The connection is like this: - TFTXCBP025 cable - TSX Premium P57453A PLC - VMWare with PL7 PRO After many testing I am now sure that my...
4,595
Hi all, I am facing problem about installation of modicon PL7 version 4.3 softawre . I had 21 days trial pack of this software.and i was installed...
2,685
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
475
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
55
