problem with read data block scl
slentnight
Jan 2015
moscow
Code:
FUNCTION_BLOCK FB283
VAR_INPUT
DB_number: BLOCK_DB;
add : int;
END_VAR
VAR_OUTPUT
out:INT;
END_VAR
VAR
end_var
BEGIN
out:=WORD_TO_INT(BLOCK_DB_TO_WORD(DB_number.DB[add]));
END_FUNCTION_BLOCK
I create 1 DB1 , i wanna read data from two address 0.0 and 0.2 , but i can't , plz help me
đź“š
Better to state that your code will not compile. Try this instead:
Code:
VAR_INPUT
add : int;
END_VAR
VAR_OUTPUT
out:INT;
END_VAR
BEGIN
out:=WORD_TO_INT(db_number.dw[add]);
END_FUNCTION_BLOCK
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,570
I am starting up a new RTU using a L306ER with a 5069 -serial to a Serial radio using DF1 Radio Modem Protocol. I only used it for reading to get...
1,459
I have a square wave being put into the Micro850 input channel 0. I have tried with counting the rising edges with code and with trying the high...
1,914
Hi All, this is my first experience with the Siemens CP343-1 Profinet used as I/O Controller for manage ET200M remote I/O. Here my actual...
2,883
Hey guys, I have one of the new CLICK plc from AD with an ethernet port on it. I made a subroutine for an IO Map of a modbus slave device I have...
4,698
