Problems connect to 400 H CPU MPI/Profibus
grebbs
Feb 2010
Gothenburg
I have a new Siemens 400H-CPU. On the rack there is a power module, a CPU and an ethernet card. I need to download the hardware configuration, however I cant connect to the CPU's MPI nor DP slot. On the profibus I have 3 IO nodes. I use step 7 and a CP5711 device.
In the "Set PG/PC interface" I've tried the CP5711 Auto/MPI/Profibus interfaces. With the IO nodes connected and not. Non works.
When selecting MPI and Profribus and DON'T tick "PG/PC is the only master on the bus" I get error code "0x013a" when running diagnostics (finding nodes).
When selecting Profribus and DO tick "PG/PC is the only master on the bus" I find the 3 IO nodes on the bus but NOT the CPU. And I get no error.
I've removed the SRAM memory card from the CPU. I've done a memory reset. Nothing seems to help.
Do you have ideas of what could be the cause? Ideas to test?
Thank you for help!
Regards Andreas
More info:
In the "Status/Network diagnostics" I get error: "Error 0x031a: No active PROFIBUS/MPI network found...." when connected to the profibus port.
Here's an update.
In the small town I am at now, I found a automation company. They had a computer with a CP5512 interface card in it which I was allowed to borrow today. With that the profibus port on the CPU was still totally dead. However, the MPI was alive. With that I was able to download hardware configuration. After downloading that the profibus port went alive - also with the CP5711! The ethernet card also works, so now I can use ethernet only.
Cheers :)
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
129
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
145
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
190
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
301
