Problems Connecting Cognex and Twincat
Sep 2021
NA
I am attempting to establish communications between a Cognex camera and a Twincat PLC. I have followed the steps given be Cognex here:
https://support.cognex.com/docs/des...ptional Communications Plugins|TwinCAT|_____1
Unfortunately, no luck so far. I am trying to figure out if the Cognex is supposed to be connected via a standard Ethernet network, or if it should be linked to the the Ethercat network. If anybody has any suggestions, I would really appreciate it.
Did you copy the Cognex device’s ESI file to the "C:\TwinCAT\3.1\Config\Io\EtherCAT" folder? Does TwinCAT detect it? There are many tutorials in the Beckhoff website for setting up TwinCAT IO. It takes a bit of time to get used to it and the errors and warnings are sometimes cryptic. But once you get it to work it normally works very reliably.
Cognex didn't provide a ESI file. They just say to connect the Cognex to the Ethercat device and the Cognex should communicate using the ADS protocol.
As a side, we were able to connect the cognex device to a laptop running Twincat, but it is super touchy. It seems to be dependent on setting up static routes in a very specific order, which seems weird. Still haven't gotten a viable connection to a Beckhoff PC.
If it only supports ADS you need to use the firewall settings in order to open the required TCP and UDP ports for the ADS protocol. The Bechoff knowledge base explains what needs to be configured,
What is the model of Cognex camera? I don’t think many of them support EtherCAT protocol.
Your link is for Cognex Designer which is a PC vision software. The self-contained InSight cameras… I don’t think so.
I've recently discovered a problem with a 1756-ENBT/A card, where i get the red X in linx and cannot browse to it, when sitting at my desk. The...
2,014
Running Windows 7 Professionsal with VMware® Workstation 14 Player on a Windows 10 host and having trouble connecting to devices (barcode scanners...
1,890
Good morning, I have a bizarre issue with connecting directly to a Micrologix 1400 via ethernet. It recently popped up on a service call when...
5,886
I'm currently doing a project where we have to connect a AllenBradley PLC 5 ReadiPanel to a AllenBradley PLC 5000 over DH (RIO). in order to...
1,159
Hello, Regarding the Modicon M340 disscusion, I am having some problems regarding a BMX P34 1000 processor(version 1). I am trying to connect it...
2,471
