Problems converting S5 STL
zonttux
Feb 2020
Finland
Hello, I am working on a project to convert a program from Siemens S5 to Twincat. I have little trouble understanding how the parenthesis work with STL. I have two examples and would appreciate help on cenverting them to FBD, ST or LD.
A(
o(
o(
a f11
a f12
o f13
o f14
s f10
a f15
r f10
a f10
a f16
an f17
a f18
a f19
o(
a f1
a f2
a(
o(
a f3
s f4
a f5
r f4
a f4
a f6
a f7
s f8
a f9
r f8
The code looks almost like a riddle.
Lots of brackets and lots of SR blocks in the middle of the code.
This is an example of way too complex STL code for logic.
I think it is originally FBD code, due to the use of SR blocks in the middle of the network.
This my attempt to reproduce it in FBD and LAD.
When I switch to STL, the STL code looks not at all like the original.
What I have done in the past... long time ago
Download S5 for Windows by IBH and run the demo, make a S5 project and in OB1 write it out and swap between LAD and STL
https://www.ibhsoftec.com/DL-S57W-Eng
Once you make a project click on new block and use the S5 format
Good tip, but the second I add some brackets it can't make the conversion to LAD. I believe I can't simulate with this program?
Yes it's possible it's originally in FBD, since most of the code is and there are some segments here and there in STL.
Way too complicated indeed really hard trying to understand how it's supposed to write out..
Segment 13:
O(
A F 16.1
L KT 350.1
SD T 12
NOP 0
NOP 0
NOP 0
A T 12
O(
A(
A F 17.2
S F 16.2
A T 14
R F 16.2
A F 16.2
A F 16.1
L KT 150.1
SD T 15
NOP 0
NOP 0
NOP 0
A T 15
S F 16.3
A T 14
R F 16.3
NOP 0
Yes thank you! I think I'm getting a hang of it since I got the exact same result. Simple math at the end but it just takes a bit time.
I converted an intouch app from 7.0 to intouch 2014 (ver 11) and the alarming isn't working. The original app (old app/pc still running) is...
1,531
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
195
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
158
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
204
