Problems with pi services in FactorytalkView Historian
Norvator
May 2010
Lima
Hi all forum members
I have a virtual machine for testing with windows server 2008 R2, FTHSE.
I have been following a guide but I have problems
The problem is that when I open System Management Tools, an error message appears. (1)
Same thing when I open PISDKUtility(2) and try to connect (3).
In Factorytalk Administration console I can not create "New Historian Connection".
I can not find the services pinetmgr, pimsgss (4) in services.msc.
Any suggestion :unsure:
In the Program Files/PIPC/BIN folder, there might be a pistart.bat file. If so, what happens if you run it in a command window?
Not having pinetmgr (PI Network Manager) and pimsgss (PI Message Subsystem) would appear to be a significant problem, suggesting the installation did not complete successfully.
Welcome to the Forum!
I dunno about FTHSE on a VM; it is not supported; it might be supported; either way, it's cumbersome enough to install it on a physical machine.
Does your FTHSE VM belong to the same domain as the FactoryTalk Directory machine?
Did you add the FTHSE VM to the Computers folder of the FactoryTalk Administration Console Project tree?
Does the SystemDrive folder contain a file named 'Program'?
If true, Rename, Delete or Move it.
Does the ProgramFiles folder contain a file named 'Common', 'SharePoint', or 'SharePoint Portal'?
If true, Rename, Delete or Move them.
Thanks for answering
Mispeld,
In folder path ProgramFiles >> PIPC
I do not have BIN folder (1)
dmargineau,
Factorytalk SE is installed on the same pc. (2)
Yes, I did (3)
I can not find the SystemDrive folder
I do not have any of those folders you mention
This seems to be an installation issue or something corrupt.
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
133
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
145
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
191
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
304
