Daba,
I am inclined to agree that in most cases I have seen stand-alone controllers outperform PLC PID's.
That being said, I agree with Lancie that there is no sense in not using a tool just because you used to get by without it.
I have not personally seen anyone else's code that used the Integral Sum value, but I have used it in a couple of applications. What happens to the CV if the I gain is changed (auto or manual)? You may get a nasty bump to the CV and then have to wait for the oscillations to die down to see if your new gain gave you better control, UNLESS, you multiply the current I sum by the ratio of Old Ki/New Ki and write that value to the I sum.
Another way I use it is when I have a process that needs modest gains for SP change tracking to avoid overshoot, but more aggressive gains for disturbance rejection. I run a timer when the SP is within a very small error range, to indicate process stability. When the timer is done, zero the I sum, change to the aggressive gains, then write the current CV to the .BIAS parameter. This way, the bias is holding the process at SP, and the PID is only dealing with disturbances.
Yes, it is more work, and not always worth it, but my point is that if the tools are in the bag, sometimes they can be very useful, especially if a more sophisticated method like cascade control is not feasible.
In fact, any stand-alone controller that advertises "bumpless transfer" has to, by definition, manipulate the I sum on the transfer back to auto mode.
daba said:
That control loop was one of the very, very, best I have ever witnessed, and the guy deserves a mention
Sadly I forget his name, he worked for Eurotherm.
I've seen enough well (and badly) tuned loops to know that there definitely is as much art as there is science to properly tuning a loop. I have immense respect for guys who make things work beautifully with the tools at their disposal. But don't you think this same guy would have used any information about the process and the PID controlling it that he could get his hands on if it provided more accurate control?
Lancie1 said:
Well played, sir, well played.
