Problems with step 7
rulomi
Apr 2010
Moza
I use the CPU 417-4H from Siemens with the Wincc interface. To the system are connected analog inputs SM 331 that are not connected to anything (just a resistor). Even that they are connected only to a resistor and they are in a closed cabinet with no vibration they are giving from time to time a wire break message. The wire break is not consistent with anything and is coming randomly just for about 20 msec each time. Did any buddy have this kind of problem? Does anyone knows how to solve it?
I had similar issues, I ended up just not using the diagnostics for wirebreak (setup in hardware config) and creating my own wirebreak alarms by comparing the actual value to my determined wirebreak value.
The nice thing about this is that if you have one that flickers you can always suppress it with a timer
thank you for your answer. We can't stop using the diagnostics. Did Siemens helped you with this problem? Do you know exactly why it happened?
Hi, this is my problem, I created an app on FT Administration Console, in fact, one for network and one for local, I changed the connection to...
1,688
Hello Guys, I am new the forums ad well as a novice programmer/troubleshooter. My software is Siemens S-7 for a 300 PLC. My problem: Coding, I...
1,688
Hello! I have problems with two System Electronics Quad Remote Microstep Drivers. From notes added to them, I know that one don't control motors...
1,860
Hi' Does anyone of you expirence any problems running Step7 under windows 7 ? In the last couple of weeks I have had some wierd problems with...
13,964
I tried to archive a Step 7 project today and ran into a problem I have not seen before. I have a customer with systems at several locations, so I...
2,533
