Problems with vba conversion
Drewcas92
Jul 2015
NC
Hello,
I am converting an rsview32 application to 8.0 factorytalk SE
My displays and tags converted successfully(totally unexpected). The only thing that didn't convert is my vba code. basically I copied and pasted from the old application, matched up the reference types and set it up to run on screen launch. It complies ok but on run-time I get 'Error 429 ActiveX component can't create object'
I strongly believe it's an issue with the reference types, my question is are there any known problems with old reference types not working on the 64bit factory talk view?
the types i'm using on the old are:
Visual Basic for Application
RSV
OLE Automation
Microsoft Forms 2.0 Object Library
RSView32 Object Model
Microsoft Common Dialog Control 6.0(SP6)
Any tips are appreciated
Are you using the same references in View SE?
There is also the case that in SE, ALL VBA code is tied only to the display it is written with. There is no global, or stand-alone VBA code in SE.
I set up all my references to match yes.
I also have set one display to host all of my VB code, and have that window launch in a startup macro and it is set to run in the background. I get the message, ActiveX component could not be created
What control/component are you trying to instantiate?
VBA in FTView cannot create objects that are graphical at all, they have to exist prior to use.***
*** Edit to add - Yes, FTView VBA can create a graphical object on an open display.... even an ActiveX object, but in the case of an ActiveX object, it involves so much hacking and trickery and bad coding that it really is a horrible idea to even attempt it.
Gotcha. Well I found out that part of my problem was that yes, the old application was creating graphics. I have gotten all of that fixed. My next mountain to climb is getting basic functions into this thing. This application is pulling a recipe out of a spreadsheet, populating the values into the application which can be edited from there and transferred to the PLC. Not sure exactly what the PLC is doing but I don't think that will effect what I am trying to do to the application. Thank you for your help thus far and any advice you can continue to offer.
Version 6.30.17 very old Project has not used vba scripting prior to this problem Took the 6.30.17 project and put it into a 7.20 version...
5,121
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
199
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
160
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
207
