Processor back to factory default
randy
Supporting Member
Apr 2002
158
I would like to return a SLC 500 5/04 back to factory default. I believe I have to remove the processor from the back-plane and jumper between GND and VBB.
Is this correct?
rmonroe
Yes, thats correct.
A couple more reminders
  • Power down the rack before unplugging the processor and leave it powered down until after you reinsert the processor.
  • Unplug the processor battery BEFORE shorting the VBB pin to ground.
My over all goal is to communicate using the USB (DF1) converter. I wanted to set the processor back to factory default before trying. I'm using SLC 5/04 processor and the 1747 UIC driver for RSLinks.
Using the RS232 (DH485) port on the USB converter (COM Port4) and the switch in the right postion I am not able to communicate with the PLC. But if I go directly from my PC Com port (re-configured port com1) to the PLC I have no issues.
I then switched processor (SLC 5/03) and using now the RS485 (DH485) port on the converter (com port4) I am able to estabish communication.
I'm not sure what my problem is...maybe I need some help?
Thanks for your support
rmonroe
The 1747 UIC is exclusively for DH485 communications - despite the fact that it has a 9-pin D connector on it. This has caused considerable confusion among people. The 9 pin D connector is used for communicating with PLCs on which Channle 0 has been re-configured to talk using the DH485 protocol.
If you are using the default DF1 protocol, you need to use a standard USB-RS232 converter (I use a Keyspan converter when I need one) or your computers RS232 port to connect to channel 0 of the PLC.
Save the UIC for talking to SLC5/01 and SLC5/02 PLCs.
Hi Everyone, Customer is asking me to put their Spare L73 processor that I was using for development back to "Factory Default". I know I can put...
2,392
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
315
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
103
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
111
Hello all, I have been experiencing dropping network connections on the Co Pro quite a bit, 3 times a month. The remedy that we do to bring the...
764
