Produce/ Consume In RSEmulate V21
Jul 2007
Kiruna
600
Hi all,
Is it possible to use Produce/Consume tags between 2 Emulate controllers over the backplane?
I cannot get it to work. All is good in IO tree until I add the consume Tag then I get an error code 16#0203.
As far as I know, it is not. The Emulate controllers don't support any kind of cyclic I/O connection whether over the backplane or over a network, with the exception of the 1786-SIM module object.
The SoftLogix controller might support it, but as far as I know the Emulator doesn't.
Hi Ken,
It seems that way. I was reading: Getting Results with Emulate 5000 which suggests it did:
Configuring Produced and Consumed Tags
Another method for simulating I/O for your emulated project is to produce and consume
tags from another emulation module. (See the documentation for your Logix 5000
controller for background information about produced and consumed tags.)
https://rockwellautomation.custhelp.com/ci/fattach/get/96143/
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
178
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,126
Recent Forum member and very-good-question-asker /DesertSurf520 has a thread that started a discussion about Compact 5000 I/O, but branched off...
1,858
My PLC has a Boolean consume tag that gets data from another PLC via ethernet. Is there a way to make the consume tag fail to 0 when the ethernet...
2,756
Hello Ladies and Gents, I have some PLC to PLC communications using Produce and Consume. The data is not time sensitive, and I really only need...
4,657
