Icekold Member I Join Date Sep 2012 Location Indiana Posts 16 Sep 24, 2018 #1 Is there a way I can retrieve data from a Productivity 3000 cpu remotely? Thanks.
g.mccormick Lifetime Supporting Member G Join Date Jul 2012 Location IN Posts 961 Sep 24, 2018 #2 Do you have connection to it remotely via network of some sort? The pseries has built in webserver where you can download the datalogs. This is of course assuming you set up datalogging and can get to cpu via ethernet connection
rdrast Lifetime Supporting Member Join Date Apr 2003 Location South Carolina Lowcountry Posts 5,544 Sep 25, 2018 #3 The Kepware OPC server that AD sells works fine with the Productivity PLC's.
Icekold Member OP I Join Date Sep 2012 Location Indiana Posts 16 Jan 13, 2020 #4 Productivity 3000 email setup Hello, I've been trying to setup email alarms using productivity 3000 P3-550. I followed an online video but not doing something correctly. if anyone can help I would appreciate it. Thanks
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Jan 13, 2020 #5 Try looking through the threads at the AD forum: (not sure if my search results link will work): https://forum.automationdirect.com/...SON={"keywords":"email","channel":["109816"]}
Gene Bond Member G Join Date May 2004 Location Hoosier National Forest Posts 585 Jan 13, 2020 #6 https://accautomation.ca/productivity-1000-series-plc-email-and-text-communication/
gclshortt Member Join Date Dec 2014 Location Ontario Posts 3,217 Jan 14, 2020 #7 +1 Gene. Thanks for the reference.
