Proface GDU question
icehube
Nov 2005
ohio
86
We are currently using Proface gdu's in our building. Is there a way to get the amp reading from the drive which is connected through devicenet to the gdu? Would help us out more that opening the panel and going to that parameter....just wondering.
I confess I know nothing about devicenet but if the drive is controlled by a plc and the Proface unit is on the network then you should be able to. I know that if it were Profibus, the speed and current readings are sent back to the plc and can be easily displayed on an HMI.
thats kinda what i am after jsut a way to monitor the amperage....i know for a fact ur right about profibus because i have worked with it before....just not sure where to find it in the devicenet part...anyone know?
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
171
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
203
Has anyone found a Proface HMI that is compatible with Schneider M172 PLC?
401
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
358
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
501
