CompactLogix MSG Read from Proface?
timryder
Feb 2007
Macomb MI
176
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor built with Proface HMI's and I wanted to pull data out of those PLC's with my central CompactLogix directly... but I don't know if this is possible? I am aware about adding a new device to the Proface project for AB, but I believe this makes the Proface the master and not a slave. Does the reverse exist?
Is Modbus the exchange protocol? If so, you can use my or Rockwell's ModbusTCP Client AOI to initiate reads from the CompactLogix.
I was hoping not, I was hoping there was some other more elegant way to do it. Yes I am also aware of the ModbusTCP AOI and thank you for the sugestion!
Hello Everyone, Can two PLCs on two different subnets pass data via CIP MSG Read Instructions? I would be using the HMS Fl3xy NAT 1:1 feature to...
2,472
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via...
1,127
Good Evening , I'm finally understanding a MSG instruction a little better. My question is , I'm using a MSG read in a CompactLogix to see...
1,909
Hi Guys, Currently trying to read an int from a MicroLogix 1100 with a CompactLogix L16ER using the MSG instruction. It's setup in the L16ER...
4,195
I am trying to set up a MSG read in a Micrologix 1500 LRP series C to read data from a Compactlogix L32E via a NET ENI series D. I have...
8,526
