Compactlogix MSG read PLC5 via ethernet. Can't cache connection?
hardaysknight
Dec 2015
Southeast USA
117
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via ethernet, and I was given the option for the MSG configuration to cache the connection, so I did.
However, I'm using a similar setup on a different machine to read from a PLC5 to a Compactlogix via ethernet, but I do not have the option to cache the connection (it's greyed out). Does anyone know why?
Does anyone know if is possible to read data out of a ProfaceHMI/PLC into a CompactLogix PLC? I have a bunch of OEM machines on our plant floor...
495
Hello Everyone, Can two PLCs on two different subnets pass data via CIP MSG Read Instructions? I would be using the HMS Fl3xy NAT 1:1 feature to...
2,474
Good Evening , I'm finally understanding a MSG instruction a little better. My question is , I'm using a MSG read in a CompactLogix to see...
1,909
Hi Guys, Currently trying to read an int from a MicroLogix 1100 with a CompactLogix L16ER using the MSG instruction. It's setup in the L16ER...
4,199
I am trying to set up a MSG read in a Micrologix 1500 LRP series C to read data from a Compactlogix L32E via a NET ENI series D. I have...
8,526
