hi2pratik Member H Join Date Oct 2013 Location nasik Posts 10 Nov 2, 2015 #1 Proface HMI and Fanuc CNC communication is possible or not
RussB Lifetime Supporting Member Join Date Oct 2003 Location Michigan Posts 2,914 Nov 2, 2015 #2 Maybe. With a Fanuc CNC you will need to verify what communications options the designer has given you the user access to then see if the Proface device has something compatible.
hi2pratik Member OP H Join Date Oct 2013 Location nasik Posts 10 Nov 2, 2015 #3 About siemens CNC which communication port is available with siemens CNC controller to connect with Proface HMI plz help
RussB Lifetime Supporting Member Join Date Oct 2003 Location Michigan Posts 2,914 Nov 3, 2015 #4 hi2pratik said: which communication port is available with siemens CNC controller to connect with Proface HMI plz help Click to expand... Siemens makes a CNC? News to me.
bkottaras Member B Join Date Oct 2005 Location Chicago Posts 1,802 Nov 3, 2015 #5 What he may have is a Sinumeric controller similar to Simotion. I'd look into Profibus or even Profinet comms supported by ProFace if I were you.
Izabela Member I Join Date Jan 2007 Location United States Posts 32 Nov 5, 2015 #6 Yes if the Fanuc CNC supports some common existing protocol SNP?? Modbus??
