ProFace HMI to Mitsubishi PLC
woolie161
Aug 2012
Eltham
73
Hello Everyone,
I am hoping someone can point me in the right direction.
I have a Mitsubishi PLC FX3u connected to an old ProFace GP2500 HMI Ver4.35 via serial.
The HMI tag for a "Keypad Input Display Setting" data entry box is LS0206
See attached image.
Can anybody assist with where this tag will write to within the PLC?
Thank you
Woolie
Its not, LS bits are local internal bits/words so probably not used or are used internally in some sort of script or function.
The chances are the original programmer used the default [PLC1]Dxxxx etc. for the PLC addresses.
Thanks Parky,
That makes a lot more sense. Although I haven't found any scripting within the project, I have found a page buried deep that uses a "D" register for the input value. This project has over 60 pages, but from what I can see only 8 are accessible to the Operators. Go Figure!!!
Once again, thank you for share your knowledge.
Woolie
It is often the case, there is probably no need to reference the keyboard in the PLC, the variable you are editing is the only thing that needs data, the edit field automatically calls the keyboard.
I'm not sure why the PLC needs to know but it's that long ago since I did any proface.
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,923
I am trying to make communication possible between the mitsubishi FX-2N and a proface HMI, ST401. all the other areas are working fine eg i can...
3,913
Hi there, is anyone here have the connection config. (or have been done before) of Mitsubishi FX PLC (FX1s-14MR-ES/UL) to Proface HMI...
6,747
I have followed the videos & still having issues getting the email out. Does anyone have knowledge or has sent an email notification via gp pro ex?
193
Has anyone found a Proface HMI that is compatible with Schneider M172 PLC?
386
