Im trying to setup the communication ports between a Proface ST401 AG41-24V and an AB micrologix 1500 (LSP 1764 series c).
First i made the cable:
Both end made with rs232 9 pin , one end plugs straight into the
touchscreen and the other plugs into the 1761-CBL-PM02 cable(also used to download programs into PLC). Im using RSLogix 500 with RSlinx classic and GP-pro/PBIII package 03.
Here is the pin layout:
Pin 3 to pin 2
Pin 2 to pin 3
Pin 5 to Pin 5
Pin 7 to pin 8 only on the ST 401 side.
Connector shell to cable shield on the ST 401 side.
After that i set up the comunication ports as followed:
ST 401 settings
Speed
19200
Data length
Stop bit
Parity
Even
Flow Control
ER (DTR/CTS)
SIO type
RS232C
DH address-GP
DH address-PLC
SIO type
RS232C
PLC SETTINGS
Baud rate
19200
Parity
even
Node address- -
Driver
DF1- - Half- -duplex slave
Control- -line
No handshaking
Error Detection
BCC
EOT Suppression
Not checked
Duplicate packed detect
Not checked
Poll time out
3000
Message retries
Pre transmit
delay
All i have on the touchscreen is one start one stop and one reset button.
When i connect the plc to the screen an error comes up on the screen and says that the PLC is not responding (error code 02:FE).
I also tried what i found on the thread below:
http://www.plctalk.net/qanda/showthread.php?t=18563
All this without any success..
Any help please..
Pin 3 to pin 2
Pin 2 to pin 3
Pin 5 to Pin 5
ST 401 settings
Speed
19200
Data length
Stop bit
Parity
Even
Flow Control
ER (DTR/CTS)
SIO type
RS232C
DH address-GP
DH address-PLC
SIO type
RS232C
PLC SETTINGS
Baud rate
19200
Parity
even
Node address- -
Driver
Control- -line
No handshaking
Error Detection
BCC
EOT Suppression
Not checked
Not checked
Poll time out
3000
Message retries
Pre transmit
delay
Any help please..
