Profibus and OPC servers
benji
Oct 2008
syria , Aleppo
72
hello
im trying to connect s7 200 plc with computer software (opc client)
buy using an opc server on the same computer
so im worried about the plc/opc server connection
should i buy an ethernet module to be able to do that?
is it possible with Profibus dp (the s7-200 can be a slave only)?
any other communication options?
thanks in advance for any help
The OPC Server from Siemens is called PC Access (6ES7840-2CC01-0YX0). It works with PPI and ethernet.
There are several 3rd party suppliers which you can locate easily with a little web searching.
anyways i was wondering if i can include another device into the ppi/usb cable
is there a ppi cable with more than 2 ends?
what advantage does ethernet give over ppi cables?
Cable with more than 2 PPI ends? no, I don't think so.
You can't find a PPI switch.
I have visited a site where i saw two 414-2 DP PLC and SimatiC OPC Via 5611 Card on same Profibus network. can anyoNe pls explain me how can this...
2,201
Hi everyone.I hope someone can help me here. So, i have the problem to read out the values on my opc scout for my configuration described above.I...
2,845
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
95
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
115
