Profibus connector for Unidrive SP
Plc_User
Dec 2005
Belgium
317
We have Unidrive SP's with a Profibus commnunication card. The card is in slot 3 (lowest slot) because only one card is inserted. We also use the triangular grounding bracket to connect the schield of the profibus. It is however not possible to use the 180°, 90° or 45° standard Siemens Profibus connectors.
What profibus connector do you use, or how do you solve this problem?
Here's an example:
Profibus connector on Unidrive SP
Thank you for the picture, but the specific problem is that we use the triangular grounding bracket that is supplied with the drive to ground control wires and the profibus. If the module is in slot 3 and the grounding bracket is mounted, you cannot remove the connector anymore. Workaround would be put him in slot 2 or 1, but then the module is not supported at the back (which is preferred as read in the manual).
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
199
I was just wondering what is the purpose of the on/off switch on a Siemens profibus connector? As i understand it the end of line is always on but...
2,408
Hello World! I have a project to apply on a machine with a remote Siemens I/O connected by PROFIBUS to main PLC. Sometimes the operator has to...
1,874
Hi Please introduce to me links about various types of profibus connector in various networking protocol usage that dont speak about connector...
1,385
Hi Please Introduce a link about profibus connector.📚
2,303
