Profibus Slave Simulator
boneless
Feb 2008
OKC
1,628
Hi all.
Spending a couple of weeks testing some systems in Norway. Some of the systems have drives controlled by PROFIBUS. Instead of unpacking the drives and connecting them, would it be possible to get a device that simulates these drives?
Should be doable to have something that we assign the address and download GSD to? Right?
Sometimes the drives are not provided by us, perhaps next time it is another type of device.
Just wondering if there is something out there.
So are you looking to see that the cabling is good? If the device is not known that you'll be connecting to, whats left is the cabling and connections that will be provided. Any profibus capable device would provide a go no-go function test. Or there are network testers available that cost many thousands of dollars.
Help us here, we could guess until the cows come home.
I am not sure what is unclear.
I was wondering if there is such a thing as a profibus slave simulator. As in, I can assign an profibus ID, perhaps download a GSD, and it will show up as the device I want to simulate. All of this is in my first post.
I assume the GSD would provide all the information needed for a simulator to behave as the device it is simulating.
I am not trying to test my cabling persé, but want to get rid of errors in the system, without removing program code/hardware.
Sorry, haven't seen anything like what you are describing. A GSD file would not have enough information as to how a device behaves, only the specifics of the interface. The true test for debug is the actual device itself.
Me neither, that was why I was asking :)
Wouldn't need all the functionality, just the possibility to change value of the IO.
Just wondering if it is technically possible. Guess I found my next project
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,811
Good morning, I am looking to establish a communication between one Profibus master and one Profibus slave. I downloaded the Profibus Master...
58
14,501
Experts! Advice required S7300 CPU 2 DP 315 Master Slave Profibus.(2 CPU) In My application I have to send data from Master to slave and slave...
1,945
2,339
