Profibus speed control
May 2007
giza
153
I used to control motor speed(MM400)from analogue output module (0-10 volt) to obtain smooth variable speed
I read about Profibus and I can switch between multi fixed speed points using control word
the question is Can I control smooth variable speeds using profibus?
Can anyone help with some ladder examples of controlling the frequency of a micromaster VFD over profibus on a s7 400 any help would be greatly...
2,366
I used to control motor speed(MM400)from analogue output module (0-10 volt) to obtain smooth variable speed I read about Profibus and I can...
1,386
I'm trying to figure out how to read the actual speed reference value from the move blocks, writing to a DB that is being sent to the VFD. For...
2,642
I'm troubleshooting a speed issue in Profibus right now. I can't remember the decimal value needed for 1800 rpm in profibus. Also, what about...
1,929
Hi, Can anyone recommend a good profibus encoder that can read the speed of a shaft? I'll be using it on a S7-300. Thanks
1,772
