Proficy (Cimplicity) 7.0 problem
Schtiel
Oct 2006
West
92
When I want to connect to another computer that has Proficy projects running, an error meassage appears: "You don't have correct OS rights".
There was no such problem in version 6.1.
Operating system: Windows XP SP2
Please help.
Proficy CIMPLICITY HMI 7.0 Problem
Anybody has an experience with CIMPLICITY HMI 7.0?
It shows a message:
"You do not have the correct OS User Rights to connect to the computer"
when I try to connect a client to the server in the Cimplicity options :(
Hi, the following is from the GE Knowledgebase.
Maybe you should contact their technical support if this is not your problem
From Knowledgebase
When using Cimplicity Options to connect to a remote computer, you may receive the error message, "You do not have the correct OS User Rights to connect to the computer ."
While it is possible that the problem is due to insufficient user rights on the remote computer, this error message may also appear if the computer name you have entered is a non-existent computer or if the computer cannot be found on the network by the local computer.
Hi again, I'm trying to use an expert object 3 position selector to emulate a Hand-Off-Auto. How do I assign the PLC variables to the...
2,763
Hey guys, I have another quick question, I'm quite new to using GE equipment, but I'll make this as quick as possible (for your sake =D ) I...
8,109
I have a customer that wnats to upgrade their PLC Software from Cimplicity 4.0 to Proficy 6.0. I am wondering if anyone has any experience with...
9,975
Hi All, I have been assigned a project which involves Proficy HMI/SCADA Cimplicity. This is the first time I am using it and I don't have a clue...
6,413
Quick question for those in the know... I'm a machine builder, haven't used GE PLC's in ages, still have Cimplicity Machine Edition - no real...
5,807
