View Expert Objects - Proficy/Cimplicity
jvcontrols
Apr 2011
BC
Hi again,
I'm trying to use an expert object 3 position selector to emulate a Hand-Off-Auto. How do I assign the PLC variables to the SwitchOutput? I'm sure there is something about fxClass or linking that I'm forgetting to do... I can assign proxy variables to the HMI, but I can't do anything with them nor can I configure the selector.
The basic selector switch works, but I would like to use the expert object version.
I'm using a GE 90-30 with Proficy Machine edition.
Thanks.
After you have the object on the panel, go into the Variables and find the item you added. For example, I added test, so I find test.switchcaption[0], test.switchcaption[1], etc.
Open the Inspector to view the properties of one item. You will see Data Source as Internal. Change from Internal to PLC Access, then the field for the I/O Address will appear.
These will be variables for the HMI, so you won't have the proxy.
As an alternative, you can CTRL-drag the object and break the link to the Toolchest. Then you can unlock the object, find out how it works and change the variables used to whatever you want.
...or just someone who knows a lot more than I do. :bow: Greetings... I have a project in SE that is distributed network . There is a button on...
3,942
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
34
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
60
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
221
