Need a FT View Studio SE expert!
steveb55
Jul 2015
Indiana
...or just someone who knows a lot more than I do. :geek:
Greetings...
I have a project in SE that is distributed network . There is a button on most screens that allows the user to open a dialog to edit current conveyor tracking information. The customer has requested that the button be protected by login security... no problem, right? Well, the problem is, if this dialog is opened (with proper login) on the SE server terminal, the same dialog also opens up on the SE client terminal (and vice-versa), which allows anyone at that terminal the ability to also edit the tracking info regardless of proper credentials.
So, how do I secure this type of configuration so that the credentialed user who opens the dialog (on either server or client) has exclusive editing abilities?
I apologize if this is an easy fix, but my vast experience is with ME PV+, so my knowledge of the inner workings of SE is a bit limited.
Kindest Regards...
Steve
Steve
I have FtView Distributed app running with about 10 clients.
**We set up security in View Studio and select access level i.e. a,b,c,d...
**On main Access page (my initial start up page) have Login button with Action "login"
**Log out button with Action "login Operator Operator" this logs in operator who has limited access level.
**In client setup (Windows) we default login to Operator. thus lowest level of access
** then operator or supervisor must login with their credentials on the PC this would for instance give them access level E "engineering"
** animate button in question Expression is: currentuserhascode (E) you can change letter to your desired access level.
the key is each Client PC has to have its own security login button. ours are based on window access credentials. But I don't think it's necessary
Hope this helps and I explained clearly.
rkukl...
Thanks for the response. Sorry for the delay, out of town.
Each client has it's own login... in fact, it is a global object that we insert into every screen. Our issue is that when a high level user logs into one client, all other clients are now elevated to that same level.
Kind Regards,
Steve
Anyone know if there is a demo of view FactoryTalk ME v8.20 study, please tell me if I can coneguirlo or where can I download. Thanks.
1,836
Need to run (or transfer license ) FT View Studio 6 on my XP Virtual Machine Morning. Have old FT View projects that were created in 32 bit OS...
5,096
Hello I am using FT View Studio ME and I need help with a particular display. I want to utilize a time stamp with some information to the...
4,253
Hello guys Software: FT View Studio FT View ME Station Mark and rdcast have helped me in a big way with setting up communications using RSLinx...
29,267
Hi I have an error on the screen saying df1 driver has failed to autoconfig com1.there for will not start ??? I am using ethernet, with...
1,714
