Need help with review studio
stu
Aug 2005
England
784
Hi
I have an error on the screen saying df1 driver has failed to autoconfig com1.there for will not start ??? I am using ethernet, with compactlogix ? Any idea what I have done wrong? Thanks stu
Hi
The advice on the AB/RA Knowledgebase is to delete the DF1 Driver if you are not using it. You can also uncheck AutoConfig. KB41928
Stu...
Hi how do u delete the driver? Or un check the autoconfig
I am not sure about RSView Studio, I don't use it. Here is a quote from the KB Article.
Getting error on my terminal, "DF1:Driver failed to auto configure Com1: and therefore will not start." I am using something other than the DF1 driver (Serial) to communicate with my PLC.
In your target tab of your application you need to right click on the "DF1P2P, Serial DF1" driver and select properties and uncheck the "Use auto configure" box. Or simply delete the driver if not required.
The problem is that the serial port is trying to auto configure to a port that is not connected.
Surely there are some Help Files and Manuals that installed with RSView Studio.
Stu.....
I am having a problem getting the jmp and lbl logic to work in my program. I have attatched a copy of the program and would appreciate it if...
22
10,057
Guest
G
50
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
173
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
76
