Profinet Display
cjd1965
Apr 2007
UK
1,659
Hi Does any one know of a Process Indicator, 24V DC that can display a value read by Profinet
Google
www sartorius-intec com/fileadmin/fm-dam/sartorius_media/Industrial_Weighing/DataSheets/English/X3/DS-X3_process_Indicator-e.pdf
www siebert-group com/docs/Siebert/series%20S302_SX302/BAL/EN/BAL%20S302%20PFN%20IRT%20EN.pdf
thanks but too expensive I have a Analog out and a £75 process indicator that I am trying to undercut
Profinet runs on Ethernet, is there another Ethernet protocol available at the processor in the system? Most will do Modbus TCP/IP also. If yes there are plenty of low cost touchscreen devices that can talk MB TCP/IP.
Thanks for replies the scope has changed and need onboard IO
OSMANMOM that last link of yours looked perfect I have added that to my equipment master file thanks
Rather than re-invent the wheel, I don't suppose someone has nay blocks for writing to the Siebert displays ? In particular the SX202 8 char 50mm...
2,007
Hi I am looking for suggestions for a small (ish) text display (5 Chars) that has 8 DI and DO Prefer 24V DC Siemens don't have one. Cheers
1,914
Where can we find a large display similar to the below but with a profinet port? It is used to view process speed and process alarms. LCD Display...
3,385
352
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
509
