Program already attached in Proficy 9.5
Hasnain Ali
Mar 2024
Lahore
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading the program it gives an error message (Program already attached). After facing this alarm old program is washed out and new program is unable to download, and PLC goes to fault mode.
First, why do you think you need to download while Machine Edition tells you that logic and configuration are equal?
Second, what is the text of the fault in the CPU fault table?
Third, there is an error number associated with the "Programmer already attached" fault from Machine Edition. Look that up in the help files for possible causes and remedies.
Hi guys, I really did not want to do this but I could really use some help. I have a traffic like project due soon for college and I could really...
2,165
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
82
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
92
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
169
