milldrone
But as a more basic question I have, does my approach even make sense?
Yes but you will have about 120 lines of code minimum just to define what position needs to move where. I'm attempting to attach a "bit twiddleing" version that uses much fewer lines of code to define which load needs to move where.
Also, am I correct to use X0, X1, ETC. AND Y0, Y1, Y.... as my input and Outputs?
Yes this is correct for Automation Direct (Octal numbering zero inclusive).
(as I have seen the use of C0, C1 for outputs - and I just don't have enough understanding of the differences).
C bits are internal bits, and do not go to the outside world.
Here is a bit twiddling version that is written on an DL06 plc (easily transfered to a 250-1) I used addresses X100 - X105 instead of X0 to X5. When I tested this against the variables as I understood them it all worked.
