ndzied1
In another thread (http://www.plctalk.net/qanda/showthread.php?t=15858) the topic of naming contacts was brushed upon. It actually can make understanding a program later straight forward or a bloddy mess.
What are the standards people follow in naming their elements?
I've mostly delt w/ RSLogix 500 so my answers will be skewed to it. For this I've almost exclusevely used Address based comments where the comment is the same wherever at address is used. This also allows Comments to follow a parent element such as the comment for a Timer will be used for the Timer status bits (unless a comment is specified for a specific bit such as the Timer Done bit).
For input comments I write the verb or action last
For Outputs I always try to put the Verb or action first
For I/O I've mostly used the RSLogix Symbols for the device reference on the schematic as shown above.
For groups of bits or registers that all relate to a common function, I try to us the first 2 lines of the comment like a mini title for the function:
This is one of the biggest drawbacks I have with the IEC type programs. Especially in IL and ST, it is impossible to show a 5 line comment plus symbol for every BOOL that you use in the program. True, you can use creative tag names and this helps but it does not compare to what RSLogix has for commnenting capabilities.
Part
Advance
Cylinder
Extended
[PROX_256]
Extend
Part
Advance
Cylinder
[SOL_352]
Auto Cycle
Step 01
Index Table
Started
[AUTO_01]
Auto Cycle
Step 02
Index Table
Moving
[AUTO_02]
Auto Cycle
Step 03
Index Table
Complete
[AUTO_03]
