Program in a TP170B
Michel
Guest
M
I need modify an existing program in a TP170B. Is possible to transfer to an PG/PC an editing it?
Thanks,
Michel
not sure. i've not had any success wit older panels such as tp27, op17. protool v.6.0 purports to have an upload facility (not sure about previous versions) but i'm sure i read somewhere it will only work if the panel was sent the original source code or full project or something? the tp170b may be different but it is still configured with protool (maybe wincc also?), you'll have to get the s/ware anyway if you're going to attempt anything with hte screen, even if you get the original program.
Yes- BUT
only if the 170B has the compact flash card inserted and the
designer used the "enable upload button"
I doubt this was done.
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
108
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
93
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
169
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
123
