CharlesX
I need to write a LADDER program in STEP7 that will interface an APEM industrial joystick (js9000). The supply voltage is 15V max.
The joystick has to control a two-axis linear electric drive.
i.e if the joystick is held in the up direction, the x-axis drive moves up
if it is held in the down direction, the x axis drive moves down, etc.
I attached the spec sheet for the joystick. I also added a connection diagram. I only have to do the interface of the analogue joystick.
Can anyone show me how to start this program
I'm a novice.
C
I'm a novice.
C
