Programming a Scada system for a S7-200/300 PLC
stevennoppe
Apr 2007
Belgium
Hello,
I would like to know if it's possible to create my own windows application, that can communicates with a Siemens S7-200 or S7-300 PLC?
I know VC++, VC# and VB, so programming isn't a problem for me and I also know a little about the S7 PLCs.
What would I need to communicate with a PLC?
A CP 5613 - PCI Card from Siemens, to connect my PC to Profibus?
Where can I find the Communication protocol and if possible some tutorials/manuals?
Does Siemens have its own communication protocol or is there a standard profibus protocol?
Thanx in advance for any help!
Hi steven,
try this.
libnodave.sourceforge.net/
its a free library that can be used with VBA,Vb, vb.net, VC++ etc, works with s7300 and s7200. best of all its free!
if you want something that siemens will support, try searching Prodave, tho i'm not sure if they still sell it. oh and almost forgot, it will work with the standard MPI /PPI comms and it supports TCP/IP
Steven,
as henry5674 pointed out, it's perfectly possible. If you're doing this out of interest, I'ld say: go ahead. But if this is some commercial project I'ld advise you to seriously consider to turn to acommercially available SCADA system, such as WinCC, Citect, InTouch and many others. Although these seem expensive, they're certainly cheaper than a roll-your-own system if your hours have to be paid by someone.
Kind regards,
hi, is there anyone in this forum who works PLC,HMI,SCADA programming projects as a online freelancer? thanks
1,291
hi experts iam new to ifix4.0 iam trying to communicate ifix scada with rs logix 5000 programming software via rs emulation 5000 software...
6,654
Hi, I got an opportunity to work in vijeo citect software. Since i am new to vijeo citect software, i just need a help to develop one button and...
6,790
Hi, We've a project with a requirement that needs ONLINE editing for the SCADA (like RSView, Wonderware.....etc) While monitoring the plant or...
4,055
Hi, I am an electronic engineer with some C programming experience, National Instruments LabView programming experience of hardware control etc...
13,852
