programming sequence
viviathevan
Feb 2012
kl
63
hello i am currently working on my program. i have some problem where i need some guidance.
i have a question where when i do the next network should i include the previous network as a output. like a sequence??????????????
for example..
i am doing network one, the lid will close when the water level reaches the high level.
network 2 : process will be when ph sensing proces..
my question is when doing the network 2, the input in the first place will be the output of rung 1 right( which is the lid close then only ph sense process takes place) then only i assign the ladders for network 2 and so on.
am i right????
My question is: when doing the network 2, the input in the first place will be the output of rung 1, right? (which is the lid closes then only ph-sense process takes place) then only I assign the ladders for network 2 and so on? Am I right????
No, you are not right. In your Rainwater Harvesting program, each network (or ladder rung) should be "stand-alone" and not dependent on the other rungs. For that reason, each network must have: an instruction that switches the Output ON, and an instruction that switches the Output OFF at some later time.
There is a method (Step or Stage Programming) where each step must begin and end before the next step starts. That is used for complicated processes with many parts or steps. You do not need to use that method for your project.
It is best if you ask all your questions in the original thread. Starting many threads, with no explanation of what you are doing, is a sure way to cause all your free help to go away.
Hello, i have a machine with 3 axis that can run simultaneously controlled by other software but sometimes this goes wrong due operator fault. So...
2,913
Hello, I am trying to make a sequence program by using MOV function to change the value of a register. So far I have always used SET and RSET for...
2,207
I am taking my first attempt at modifying a program on our little bottling machine. We need to automate a sequence to purge the tank on the...
4,820
hello all experts. i'd like to know your experiences about sequence programming. i use positive or negative edge detection(|p|or |n| elements)...
6,589
Hi again, Here is the situation..... I have now created function blocks for all my equippment in my Robot cell.. Pick and placer, Magazine...
54
48,519
