You CAN do it !!
Tips :-
1) Always , always map your physical I/O if it changes , no problem .
2) Always , Always create 30% more spare tags than you think you will need , don't worry about space , you can always delete them , but its not fun adding maybe additional PID terms after the event .
3) Buy a big A4 notepad for writing and testing , and a dayglo markers .
4) Don't try it all in one hit , for example do all you DOL motors , and write a Simulate block that copies outputs to inputs for contactor feedbacks , test it , and give yourself a pat on the back .
5) leave gaps between blocks ( for siemens FB style programming ) you never know what you might want to add on later .
6) choose a layout for your program - I like to do DOL's first , VFDS next , PID after , and then ancillary equipment , but it just depends what you are writing code for .
7) Always try to keep your layout the same , makes life easy on the next job , just copy the block and rename tags
8) keep vodka in the freezer and your bowels open
Tips :-
