Proportional valve control card
May 2007
giza
153
Hello every body
I have old machine using some of very old proportional valves.....
one of these valves control card is damaged and no one can repaire
I want to use the machine PLC "S7-300" to control the valve instead of the card....
where the valve max current 800mA and AO can deliver 4-20mA
could anybody suggest any kind of amplifier or idea?
B.R
Assumng this is electric and not pneumatic:
In the past I have encountered occasions where analog valve control wasn't working for various reasons. I have bypassed the positioner card by disconnecting the wiring between the card output relays and the contactor that moves the motor. Then I connected discrete outputs from my PLC directly to the valve motor contactor. You just keep jogging the valve motor until you get the process variable or valve position you are looking for.
+1 for this. In addition to working well, it eliminates a potential point of failure (the built-in card).
as it is probably a magnetic valve on 24 Volt, i have made a controller for this with an arduino and a FET.
Just to keep the cost low.
there are commercial valvedrivers available.
Hello, I am a part-time machine builder that has recently been exposed to the world of PLC controls. I subbed out the controls for my latest...
17
5,277
Hi All, Is it possible that from a hmi, one could operate a proportional control valve from open to closed via a numeric input or slider on the...
2,022
I'm trying to do proportional control of a valve on a water tank without the use of a PLC. Does any one has any experience using a PID control...
2,708
In the attached picture, you can see a hydraulic schematic of our installation with a proportional valve (Atos) with integrated force control...
26
11,366
Hi, I am an inventor looking for a way to automate a block-making press I made out of a log splitter. It makes blocks for building homes from...
7,226
