protect FC or FB
Create source from fc or fb. Add know_how_protect to the source and recompile. Than the block is "protected". Another option is the use of a tool to add remove the know_how_protection.
As mentioned add the text Know_How_Protect after the I/O/Stat/Temp parameters in the soutrce for each block you want to protect then re-compile.
You would need to keep the source seperate then, export the protected blocks and keep somewhere.
The only down side is this is very easy to open.
One way I've seen to make it difficult to read the code is to use UDT's extensively and then remove the UDT's and symbols from the source code. People can still get in but cannot easily dedcipher the code.
thank you it was very helpful. you mentioned its very easy to open a protected block can you explain about it .it sounds intersting
Hello Everyone, I have in an electrical panel a simple 220VAC to 24VDC power supply (as shown on the picture bellow) can this type of power...
1,367
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,571
Hi, I'm currently in the process of locking down a program, I have managed to set passwords for FB's and WS but can't seem to find a way of...
1,787
Hi I'm trying to re-program a Mitsubishi FX0-20MR-ES plc but when i Initiate transfer from GX developer it keeps asking for an 8 digit Hexi...
2,104
