protecting output PLC
smsebnaa
Nov 2014
tehran
32
I want to protect digital output of plc from reverse current. my plc controls motors with AC coil contactors.
i use selector switch to select manual or automatic mode. when transition between automatic to manual, may be reverse current is occurred.
i should use AC diode?
what is the type of the outputs?
if relais a snubber will do the job.
if transistor a simple diode over the coil should be the solution.
i use relay output contact.
when i change selector switch from automatic to manual, if plc contact is close yet, so the plc contact maybe injured in manual mode. i should use snubber?
surge suppression is used for high current, but my current is about mA only. is there any protection for digital output, when another current path comes to output if plc do not work rapidly (plc do not close contact at a moment)?
It does not matter, its more about the voltage spike created by the collapse of the inductive load. This spike can cause arcing across relay contacts and may be felt by sensitive electronics powered by the same power source.
Use surge protection for inductive loads. Cheap insurance.
It sounds to me like you are concerned that your selector switch could switch a different power source to the output via the motor starter coil wire. That is a different issue from mere surge suppression. You must wire the selector switch so that the PLC output is isolated from the motor starter coil when you switch to manual mode if you want to assure that this does not happen.
I was thinking that he thinks the load is going to momentary turn off when he makes the change.
Well, the load will switch on and off during normal operation without a selector switch. That is a surge suppression issue. However, if the selector switch circuit that he plans to use connects a different power source to the output, then that's a wiring issue that needs to be resolved. Surge suppression alone wouldn't correct that problem.
I guess that's possible, but I am not reading that into his post. I just think he is showing the same switch in 2 different states.
I guess we will have to wait for the OP to come back.
i edited and modified my last image. please see my new attachment.
my problem is stage 2. when transition occurred from auto to manual mode and plc do not act rapidly.
Sorry smsebnaa, the doc you posted only has three blank columns with a title above each. At least thats all I see
Can you give a little more detail?
Hello everyone, been awhile since I've posted..... As the title suggests, using Crimson 3.1 software (Red Lion) I cant seem to figure out if its...
1,713
Hi, Just wanted some thoughts on protecting control and instrumentation from welding damage. We had a PLC and drive fail after some welding work...
5,003
Hi Everyone, Yesterday we encountered an issue where I had a 480V 3Ph 2HP Powerflex 525 blow up. Upon further inspection, we noticed that 10...
21
6,002
Hi, I am currently developing a project and need to know if it's possible that once I download to CPU and HMI no one can upload it and re use the...
23
6,841
We have a PV+400 on our floor that has something quite odd going on. The program hasn't been changed in quite a while, at least a couple of...
5,398
