protool HMI
alireza136110
Jan 2009
iran
hi dear friend.
i have problem to open the project that created with protool when i try to open that this message appear to me: oid 5 ==oid_pop ctdriver_manager please contact manufacturer .
what that mean
how i can solve this error and open this project.
thanks.
I believe this is because the protool version you are using is older than that used to write the project that you are trying to open?
Try downloading all service packs/updates for Protool and try again.
Was the project originally integrated into STEP7 ?
Some odd errors can occur if you rip out a Protool project from the STEP7 project folder.
If the name of the project is PRO.fwd, or PRO___00.fwd, or PRO___01.fwd or similar, then it is indicating that this is the case.
salam alireza
ye soal azat daram:ta hala az touch panel haye siemens (tp177b mono)backup gerefti?ghabele edit kardan hast ya na?
mamnoon
salam. dost aziz man ta behal az transfer va download upload protool baraye backupgiri estefade nakardam man az prosave estefade kardam ke dar in halatche protool che flaxible hardo gheire ghabel edit hastand. ama ta anja ke man midoonam age ba khode protool backup begiri choon source ro backup migiri mitoni edit koni. movafagh bashi.
hi. dear friend
i dont backup from tp with protool but i get backup with prosave.
i know that when you get backup with protool you can edit and change the program.
Dear alireza
I try to backup with protool but i can't because i think this project prepare in wincc.so i thanks for our advance
hi dear friend.
when u open the project that the panel is a station of that if the simatic manager wants u to instal winccflx. that means your panel programed with winccflaxible. but i counsel u to backup by prosave for future days.
have nice time.
This is a different problem but on the same machine as my other post. Basically there is an alarm message showing up on the TP270 HMI, and I am...
6,631
HI I'm trying to download Protool Project to the HMI using seriel cable. But I am getting communication problems. Please can you help me.
2,341
Hi I have a project where the customer requires 20 users with there own user name, password, user level (5 levels). There is also a requirment for...
4,989
I have Protool V6.0 SP2 and am having problems opening the .pdb file. The first error message is as follows "Your project was created ith ProTool...
5,571
Hi Guys, I just started to make an interface for an HMI system for our siemens safety plc's on our line. I am using step 7 for the sts/lad blocks...
4,672
