Protool opening error
Kataeb
Jan 2007
www.livelovelebanon.com
636
After installing engineering software Protool v6.0 sp3 on a new laptop with windows 7 64 bits , we have the following error when we try to open it : COMOCX2.OCX could not be loaded .
What could we do ? Thank you
It has been years since I had to use ProTool. From what I remember it never got support for anything after windows XP. This may have changed.
I would say run it in Windows XP mode or a windows xp VM.
I am surprised that Protool will even install under 64 bit.
I have all my legacy software in one or more VMware images, typically with Windows XP 32 bit.
I agree. Your best bet would be to run it on a VM.
You may get a chance to make it work under 7 but defenetely not on a 64 bit machine.
it worked after doing the following: 1. set the compatibility mode of the Protool exe file to Windows XP (SP3). 2. did the same for the Protool shortcut to open the engineering software which worked only from outside the simatic (standalone). 3. reinstalled the simatic software and some of it components, because its shortcut stopped running. thank you
Hi, I have Protools V6 SP3 when I open a file I get an error. ??? If I open it in winCC it wants to convert it. All I wanted to do was change some...
22
5,127
I have Protool V6.0 SP2 and am having problems opening the .pdb file. The first error message is as follows "Your project was created ith ProTool...
5,570
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,533
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,407
Asking for a friend who has a Protool v1.0 project. He needs to migrate it, and for that he needs to first migrate to v2.51 which he does not...
1,169
