ProTool/Pro CS - Cross Reference Issue
Beggar
Mar 2005
California
47
In an effort to make my project smaller, I'm trying to delete some obsolete screens from ProTool. I first deleted all referring controls but I still cannot delete the screens because it says that they're still being used.
When I run a cross-reference, I get a cryptic message that doesn't show up in the documentation (that I can find). It says:
Is there a way that I can clear this reference so that I might delete the screens? I'm virtually certain that there remain no controls linked to the screen.
I believe that when this happens you have to send your project to Siemens and they fix it for you overnight. Send your local guy an email asking about it. No, I'm not kidding, happened to one of the other engineeers at work.
Try this trick if you not can erase objects in ProTool.
Make a new crossrefernce.
Go to the crossreference page.
Push CTRL and right click on your mouse.
In the context menu, select "Scan all log errors".
When scanning is finished, view context menu again and select
"Repair All".
Now you should be able to delete your obsolete objects.
I am in the process of moving software from one laptop to another. So far everything is going OK except I can't find the Siemens Simatic...
1,610
Apologies if this is not allowed. I have a Protool Pro PC based system that my customer is requiring me to upgrade to a TIA Portal application...
1,792
I have a Pro Tool Pro application in which I succesfully migrated to 2008 WinCC flexible advanced. I have used ProToolPro extensively but am...
2,162
hi every body i am working on SIMATIC Protool, i want to ask how to make a pop up window for an object (pump for example) so when i press the...
3,916
Have a problem in RS232 communication between Mitsubishi FX2n and Protool/Pro project running on PC. Used Protool driver Mitsubishi Fx and...
2,513
