Valera
Your prompt reply will be very much appreciated.
Now I try to solve a task -> there is 1-PC that is connected to MPI network, there is 2-PC that is connected through LAN to 1-PC. There are ProTool configuration software and ProTool RT are installed on both PC. 2-PC must read tags through 1-PC.
I have created project is named "PC-CONTROL". First I have installed on 1-PC and I set in this project option "act as OPC server". Then I go to 2-PC, run the ProTool CS, open "PC-CONTROL" project, create new project and made OPC controller. When I created it I show to 1-PC through LAN. Then I try copy tags from "PC-CONTROL" to new project. Copy is done, then I try show to OPC server place in window of TAGS. But nothing, I get "could not establish a connection to the browser interface of the server OPC.SimaticHMI.PTPro to ASU". ASU is name of 1-PC.
What is wrong?
I believe that I will get help.
What is wrong?
